Will it go into recovery mode? (Hold in Home, power and volume up) you can factory reset from there.
Try just "wipe cache partition" first and see if the phone will boot. Either that or you could try reflashing it :thumbup:
The hard reset is not working at all. I tried Home, volume and side button all together. The repair shop is saying the moisture corrode the motherboard and its unrepairable. Does internal memory (SD card) is chip in with motherboard??
Can I backup now anyhow as it not starting at all??
