Ok guys I tried this on my flytouch 3 but it failed big time...
I decided to flash 5a into my pad and went into gscript,saved the 2mp camera fix on to my sd card.
I then took the card out and flash rom 4e back into the pad.
I then added the 2mp script to gscript on 4e, loaded it and tried the camera I am still having the same green screen because my idea did not work.
Well if tim or some one else wants to write a 2mp camera fix script that works for rom 4e all that has to be done is to put a download link with the 2mp camera fix script in a zip.
Then it can be downloaded to the pc and unzip to the sd card and loaded into the flytouch 3.
I world try it my self but I don't have the software or the skills to do.
This is just an idea.
That camera fix only works wit Tim5 . .. flash it again to Tim5 then use the fix .. . It will work . . .
