FM radio, Does it work for you?
ExPalm
Member
At my desk, my 5th gen Ipod Nano's scan function finds 24 perfectly clear stations.
The Evo's scan finds NO stations.
If I manually tune the stations found by the ipod on the Evo, I can find 9 out of the 24 with acceptable reception. And, the radio app occasionally hangs up while tuning, and must be restarted before it works again.
Do I have a defective unit with respect to FM radio, or are they all like this?
(not a big deal, since I didn't even know it had FM when I bought it, and I still have the ipod for this purpose.
You realize you must have headphones connected right? It uses the headphones (wires) as an antenna.
I just thought of something, maybe this is an iPhone fix!! I am going to be rich!
As Ben pointed out you must have head phones plugged in because it uses them as the antenna. Mine works perfectly with every set I have plugged in so far... Including my car stereo audio in connection
I think everyone must - it give a dialog if headphones aren't plugged in on startup.
As noted above by htcevolee, check out the headset links - mighty important.
Mine gets weak stations well, so in theory, it's not a bad radio.
If your using TRS headphone your reception will be almost non existant you need TRRS headphones to get reception in FM radio.
Guys, like Kiz88 said, just use TRRS type headphones. To determine if your headphones are TRRS type look at the headphone jack. Does it have 4 metallic sections separated by the black bands, or just 3 metallic sections separated by 2 black bands? You want ones with 4 metallic sections. Typically, the TRRS type headphones will also have an inline mic. I have 3 of these types of headphones from previous Samsung phones i've owned and i'd never even taken them out of the box.
Basically, the contact in the Evo's headphone socket that acts as a lead for the antenna signal has to touch a specific metal band on your headphones. Standard headphones that have no inline mic, thus only 3 metallic bands, don't line up in the correct spot to act as an antenna for the FM tuner.
Do they cost much more?
FWIW - I got the $15 monobud at my local Sprint store - it _sounds_ spectacular as a mic (everyone tells me I've never sounded so good - better than talking into the phone without it is what I'm told) and works great as an antenna.
Sprint sells at least two kinds of these puppies - I've tried to look them up on the web for everyone, but can't seem to narrow them down. There's only one I recommend.
Black cord, silver bud and mic, and the cord is not cheesy vinyl, it a soft woven synthetic cloth. The other Sprint ones I've seen have a vinyl cord are all cheap - as in "just a monobud."
Lousy for stereo (obviously), but tip-top for calls and an antenna.
And per usual with this sort of thing - the button on the mic serves no purpose on this phone.
Hmm, doesn't sound right, since this would eliminate virtually every personal audio player headphone on the market.. Still, I'll try to find a cheap set and see if it makes a difference. If it does, I may have to do a plug transplant (or build an adapter ) for my Sony earbuds.
In addition to the poor reception, most times when I do a scan. it just says scanning for a while, then it will not tune anything, even from the list, until I turn the radio off and on again.
Meh.. This thing would make a lousy radio/music player anyway, given it's battery life.
Just like "Thunder18" said you've got to use TRRS type headsets or the radio will work like crap. At least that's been my experience. I plugged in a standard pair of "earbuds" into the phone and the radio reception was crap. Bought a cheap pair of earbud/mic combo (TRRS type) and the radio works great!!!!!!!!
End of story! :cool:
