new optimus
Android Expert
I would like to thank joneidy for his great information and posting the files needed.
If you have 2.2.2 then you need to downgrade, use lgnpst
The 2.2.1 rom you need from joneidy's unbrick thread
OPTIMUS M STOCK ROM.7z
Use the update prl tutorial for links and what ever to get everything needed ok. that is located
http://androidforums.com/lg-optimus-m/391622-tutorial-manual-update-3020-prl.html
ok after you have and install LGNPST you will be greated with
Then you need to open the bin the little folder icon and chose the downloaded bin file. looks like
When you get it selected it looks like
Then you need to select the prl, if you want if you don't you will keep the prl you have. but this will be a way to get on the newest one and possibly get some 3g speed.
Then after all that you will see
Now just press start, and do not unplug until the process is at 100%.
Also have a battery that has 40% or more of a charge, makes things less likely to go wrong.
Hey everyone all my screenshots are gone, and until or unless I need to create more I dont plan on it.
my pics are all hosted on my home server and I had a hard drive failure and server crash.
thanks
,i was getting mad cause metro easy wifi has stored 8Mb of data on the phone
