nitsuj17
Android Expert
Ive noticed an abnormal number of issues that people are having with themes for EB01. It seems the main problem is that many people are using the original EB01 leak and that IS NOT DEODEXED.
Your rom/system must be deodexed to use themes. Examples of deodexed roms are superclean...and now there is a full version of the eb01 leak that is deodexed EB01 Stock Deodexed - xda-developers
As of now, you must have 1 of these 2 to use themes on EB01. Or either the theme won't take, or just some parts of it will, or some stuff won't stick after another reboot.
Hope this helps clear the air.
