adrenalinerush12
Okay so I installed aHome Lite and set it as default without even thinking, and now I'm having a force close loop. I can't do anything except pull down the notification bar. What can I do? A reset? How?
- Turn the device off by holding down the power button and then selecting power off (you will be informed that the phone will be shutdown; tap ok)
- Simultaneously press and hold the Send and Volume Down buttons and while holding them, press the Power button
- You are given a screen with various information -- simply press down the trackball with the world CLEARSTORAGE highlighted
- The phone is completely wiped clean and will then reboot
- Unlock the screen and select your language of choice (English or Spanish)
- The DROID Eris will inform you that a special call needs to be made, and it will then connect to Verizon Wireless over the air programming
- When prompted, press 1 to activate the phone
- Once activated, proceed with the setup of the phone by following the on-screen directions as you did when you first purchased your DROID Eris.
I set aHome as my default and couldn't do anything. I ended up just putting the 2.1 leak on my SD card again, and holding down vol. down and end and just installed the whole OS again. Oh well. Thank goodness everything is backed up with Google.
I tried pulling the battery, I tried restarting, everything, but it kept going to that same home screen which gave an instant force close over and over.
Please someone help me. I can do absolutely nothing. I just put it into recovery mode. I don't know what I'm doing.
...set it as default without even thinking
Why don't you just restart the phone?? Unless you made aHome your default homescreen...
