Help Force Close Questions
djb28
I have noticed that when i had Voodoo a couple of my favorite apps were not working. Force closing.
Then i decided to take off Voodoo and went back to a lower voltage kernel. I restarted and the app was still not working, when it use to on the non voodoo.
So i cleared the cache and restarted. The app still didnt work. I uninstalled it and put it on again and it works good.
So now i am wondering. Is it the voodoo vs Non or the kernels you choose? Or is it just as simple as clearing the cache and putting the app on again because things get screwy with all the changes from flashing?
I put the voodoo back on to see if issues arise again and nothing has yet, almost a full day in.
I'm wondering if clearing the defaults for those problem applications might have also solved the problem.
I just removed the voodoo and flashed non voodoo. started the phone and opened the same app that was force closing.. It force closed again. I didnt uninstall this time. Just cleared the cache. I restarted and it was working fine.
Back to voodoo again. It is still working. I dont know. looks like clearing works. But it is a lengthy process to keep testing. Im bored today, But not that bored.
I love the two apps i use and dont want to get rid of them because of kernels. But i do not think it is the kernels..?
You need to go to rom manager and click on fix permissions. This usually fixes fc issues.
it wasnt the kernels or the voodoo. Like david said fix permissions and/or clearing cache solves 99% of issues
I like the new sig ;)
