Root Forget S Voice. AIVC is better
O
old_member
Guest
AIVC is this Siri clone from the Google play store it works perfectly for all my needs and it does calendar tasks and send text messages and calls and everything you wanted to do for you there's also a pro version without ads see if you want and I will try to include some screenshots . AIVC ... It is nice and has voice options
Probably forgot to add Motion to device list....
lol I should really update that lol I'm usually on my phone so I never see it. I'm running a sensation on jb but I thought gnow could be installed on the motion. Turns out it had to be deodexed Rom though.
I got pro also. Pretty good app, a little unresponsive at times but hey, we can actually have a chat with a robot lol
i have google now installed on my motion..it works rather well too....keep digging....there is one that says stock rooted roms....
I like assistant be Speaktoit. Free, Has british voice, reads my texts to me, and can be activated by shaking my phone... I use aivc & assistant ...
I asked her "would you like to have a cookie"
she answered "I'm not sure If I would like to have a quickie"
Other than that app seems to be very useful =) thanks
Wont answer my question about the weather. Tested it on other questions and it did quiet well. But it needs ALOT of improvement. I like it.
Got me the weather , I asked "Do you want a apple" since apple is iOS and it said "Do not put that apple near me , Mike"
I was using AIVC but then I updated twice it got slow and would lag in delay to my question. I searched for some more and I found Iris, this is the only application for when I said Open Facebook Application it actually did, and iris is in alpha unless siri or google now do this they are behind.
