Forums for Android™
I hope so, I've got a lot of things that I would like if they fixed
Hey, I was wondering if I should keep adding the things I say on this to my review of this app, because my review is quite long now, and it is kind of annoying to do it, I just did it for a better chance of you seeing it
https://youtu.be/UacvONr4ZfE
Video of another Android forums app glitch
I could make a video of all the glitches/annoyances in the app if you want, but it's up to you
Bold and italic and strike through all work. You just have to apply them after you type.
I just posted this from the app.
Test
I don't think it works
What do you mean? Press the button after you're done typing?
Type what you want to say and then select the word or phrase by long-pressing on it. Once selected then you hit the B or I on the formatting bar.
Test 2
There we go, I didn't think you would need to do that instead of just pressing it before typing
Hi
Oops just testing, sorry
Cool, you can turn text into a link
I tried making a part 1 to my glitches but for now I'll give up because I deleted it like right when I started uploading it, and I thought YouTube already had the file, but the upload failed. I might either not make it now, or wait a while because it took a while
I know I've already said it, but it's extremely annoying how you can't delete attached files from your post when you go into edit it.
Also when you make a post about 'apps and games (no sub forum)' then it makes it become the forums app.
For some reason sometimes when you like a post, it crashes 🤔
I think its something to do with your system font being absolutely terrible (and immature).
Alternatively, whenever I get that message, I log out, log back in again and that sorts it, albeit temporarily.
First off all, reported for being intolerant of other members' freedom of font choice.
Secondly, I'm putting you on my ignore list. :p
I only get that when I restore a nandroid backup.. I have to uninstall and reinstall Forums to get rid of the toast
Thanks for the polite, kind, and informative reply. Members such as you should be commended :)
