DsyMnapTic
Android Expert
anyone know what this system app is on cm7?...just curious.
Yeah I wasn't thinking about deleting it in particular (haha). I was thinking that maybe it was a native task killer that came with the cm7 mod, because some apps do start up upon boot and are killed later automatically by some system process.
I'm basically going to look through and delete everything possible while keeping the phone operational, just to see how bare I can get it to run. If I mess it up ill reflash being that I already have the roms on my SD card.
best way instead of reflashing is backup your current rom in cwm and if anything messes up in the process, you can always restore only takes 5 minutes in stead of re flashing.
...I appreciate that nutmeg, but I've already deleted a few things, so I'll kind of want to go back to stock CM7 and start over. I'm just kind of experimenting around with this Rom.
your welcome, also i seen another app using root explorer and saw something called pacman...lol im going to find out what that is...
lol.....yeah some strange stuff in there......
think I saw one called Illuminati brain scanner..........JK
lmao....our phone is the devil...
...an you're the advocate...jk......have you experimented with the compression on the internal memory, I know that the default is 18 percent, but have you had positive results from upping the percentage
no...i thought about changing some setting also, just to see what happens..
well I'm just trying to see everything I can do to make it run fastest, and most efficiently, so I'm thinking about raising the compression, turning the CPU all the way up, deleting everything not absolutely necessary, also....check this out, there's an option in titanium backup to convert a system app into a user app, but you need the donate version. Any how this would allow you to move certain system apps such as market to the SD card
