I know some of you have been wanting to get rid of that annoying startup sound on your phone. Here's what you'll need....(some instructions copied from Maerlim to save time)
You'll need the Android SDK (guide to download and install is here)
You'll need the USB drivers (Stickied post in this forum)
You'll need root access (look for the Captivate Root thread by chaoscentral)
You'll need Busybox (available on the market after you root the phone)
Connect USB to phone with USB Debugging ON
Open a Windows Command prompt in the SDK install directory
cd tools
adb shell
su
cd etc
I suggest backing up the file before deleting
cp PowerOn.wav /sdcard/
rm PowerOn.wav
exit
exit
THAT'S IT! I renamed the Windows 7 logon .wav file to PowerOn.wav and copied it to the /etc directory on the phone played it on startup, so you should be able to put whatever you like in there!
If you want to copy a file there.....
cd tools
adb push "the location and name of the file on your pc" /sdcard (example adb push %userprofile%\Desktop\PowerOn.wav /sdcard)
adb shell
su
cp /sdcard/PowerOn.wav /etc
exit
exit
If you don't know what ADB, Android SDK, or root access is - please don't try this and don't ask a million questions about it! Go read the forum stickies on rooting and sideloading FIRST!
cd tools
adb shell
su
cd etc
rm PowerOn.wav
exit
exit
cd tools
adb shell
su
exit
exit
Easier to rename it.
