Root foxfi = infastructure mode on transform ultra
well thats good to see, it also said in the description that it doesnt require root can anyone thats not rooted confirm this? chances are it will require root for the Ultra
I can confirm foxfi works on both rooted and unrooted transform ultra! Mine is rooted, my wife's is not both work great with our android tablets!
For some reason its not working for me..i tried tethering to my galaxy tablet and nothing...my wife tried her kindle fire and it connected but signal bars have an x next to it...my tablet does connect but nothing happens...is there something I got to do wether it be an option I got to mess with or numbers I gotta change...can someone help?.. Thank you in advance!....
i would try rebooting both devices. and then just keep turning foxfi on and off..it takes my computer at least ten times of this before it will connect but my nook simple touch connects perfect as does the gf's...she can also connect to my wifi connection through her phone(htc hero) on my tether connection. just play with it but as far as settings i haven't changed anything since i downloaded.
hope that helps.
james
I had a similar issue. Turned out it was my software firewall causing the problem. After I told it to allow connection to a new network everything worked fine. Hope this helps.
hope that helps.
james
Thanks james ill try it out and let ya know what happens...
Cwoo ill also try out your suggestion as well so I also will let you know..thanks a million fellaz!!!
Foxfi does work on the Unrooted Samsung Transform Ultra. Just remember to manually set the DNS address on the laptop or tablet you are using to connect to the phone. The phone assigns a DNS address automatically from Virgin mobile.It must be blocked. It was 192.168.47.224. Manually set the DNS address to 208.67.222.222.
Speed was not the best but was usable.
I was having trouble with the tether stopping randomly, turns out juicedefender dosen't play well with foxfi. I need to disable juicedefender whenever I use this. Then it works perfect. Haven't messed with dns or anything else. Hope this may help someone out there!
Lol xbox360 here also. Works great with these speeds. Mw3 yeah baby.
works just fine on my PSVita where I don't have to use up my 3G plan just getting demo's and for the options that require a AP...should work fine on PS3 then
Rooted , backed up(cwm), flashed with star-scrom and did the bobz OC kernel/wifi
FoxFi doesn't work though .... it appears to function properly but as soon as i activate it and try to connect with my ipad ...... my ipad say something about server connection issue??
Any thoughts? All flashing went perfect and seems great but this is a issue, my old wireless tether had ad-hoc errors .... i might have to go back if this doesn't work though?
Any suggestions?
I have setup the foxfi and connected my xbox360 to it; however, the Nat type is strict so cannot really use xbox live to play BF3. The Nat type on my old server was open so could talk and connect to everyone without a problem.
Does anyone have advice on this aspect of it?
I am using a Virgin LG Optimus Slider Android phone if that info is needed.
Thanks
P.S. I have a Virgin 2200 wireless device that has the same trouble with xbox live
I dont have an xbox but try tethering your computer to it and running a cat5 between your comp and xbox. Not sure but I think you'd need a cat5 patch cable
would someone be kind enought to post the apk. I cant find it in my market i searched for foxfi and fox fi both do not show the app.
most easiest way to get an app not in the market is use ur stock browser and in the browser window type out what u need "foxfi.apk"in ur case.Thats how i always find stuff i want lol.
Here ya go guys... You can download it from their website...
FoxFi Installer
Sprint made google remove it from the playstore... Just remember if it's not working for you... You will have to turn on your wifi on your phone BEFORE loading up FoxFi... Make sure you do not connect to any wifi access point... Then run FoxFi as usual...
:D:DYou're Welcome!:D:D
