I am trying to get wifi hotspot on my lg motion 4g. When I try to start the wifi connection, it says wifi mode has failed try bluetooth dun instead. Bluetooth dun dosent work either. Im am using foxfi through pdanet. I can use pdanet usb tether just fine with user agent switch on google chrome.
I am not rooted. I have tried reinstalling, rebooting, changing ssid, but none worked.
Could it be possible to try the build prop method? Without rooting?
I have foxfi wifi hotspot working perfectly fine on my lg optimus m rooted and custom rom, so i know it works good with metro pcs.
