MusicJunkie
Android Expert
What are the difference between the 3 versions of the Freedom kernel for sense ROMs?
voltages are setup differently for the various romslithid@MPDI:~/Development/Htc-Sense-Freedom-Kernel$ ./build-it.sh --help
Usage: build-it.sh [OPTION]
Here is a list of available options:
-F | Build Stock Freedom
-L | Build Less Freedom -75mv
-M | Build More Freedom -125mv
-A | Build Aggresive Freedom -175mv
-ALL | Build all versions
Aggressive is the most undervolted. More is a little bit less undervolted. Less is less undervolted than that and stock is the stock voltage.
The three types you were referring to....universal is for basically everything. Synergy nightly is for the synergy nightly builds (not even sure if they're doing this anymore) and the godmode build was for the synergy godmode build only.
Ah, well it's all good! The Freedom stuff is confusing because there are so many different versions. You should try out the new Anthrax kernel. Seems to be working pretty good for me now. Need to wait a couple days to see how the battery life compares.
That's cool, if your phone acts weird (reboots, etc) try the More Freedom build. I've never even tried Aggressive Freedom on my phone, but as weird as it sounds, I get as good or better battery with the stock kernel.
for me aggressive does really well on my phone. just make sure that you give the kernel sometime to settle in before moving on.
