Fresh 2.3.3 Released
Facebook issue- not sure. Sense is soooo intertwined with facebook that if you don't have sense, you will miss all the little things. I just check mine through the browser most of the time. My contact pics synced, eventually.
The kernal is already overclocked to 710 with this ROM, and I don't think you will need any memory tweaks, as with all my apps loaded, I have about 90 mb free space (without using the native froyo a2sd). The Rom is about half the size of any other I have run so far.....
As far as the mms/and the camera issues, I have never had a problem with receiving a picture through mms, and I just use the app camera magic in the market, and it fixes the preview feature in the camera.
thanks, these custom roms are so confusing, compared to stock roms, there are so many add-ons for this froyo release, im just lost.
does it support full flash (10.1)?
so this rom automatically runs @ 710, or is it changeable?
Not sure about flash but with that kernel it will scale up 710 when needed. I'd still setup overclock widget to scale between 245 and 710 as these kernels are kinda buggy still without an OC app.
I don't know if you can use setcpu, or overclock widget with this rom, I don't and it runs fine.
As far as flash is concerned, I have no idea if it is full flash or what....
If you don't flash the overclock kernel then don't try to overclock, it's actually counterproductive without the custom kernel.
i am using the overclock widget ATM, set at 528mhz.
is there a overclock kernel that i can use w/ the sprint 2.1 (ver.5, not .6) rom?
im so lost looking at all these roms, b/c you got these color packs, etc, which is so confusing.
i have real bad adult ADHD, so i comprehend/learn better from visual stuff like vids, any vid links i can watch to understand how to install these custom roms, b/c the sprint RUU rom instructions were very step-by-step
what about the issues w/ video, & 5mp cam, not 3mp.
is there any vids or screen shots on this rom, b/c i like to look of the htc sence, so id like to see what his looks like, & how can you say itas stable, if HE says its not 100% working?
thanks for everything
if you flash the CM 6.0 test4, then flash the current update http://mysticmead.com/hero/ubertesting-warning-catwillbeeaten-norefunds.zip you'll have a 5mp camera. no preview but the camera does work. use camera magic to get a preview. the video camera is still not working. MMS is fixed.. join teh WebIRC to find the latest daily build and to get any support on Froyo http://webirc.fossnet.info:9090/?channels=hero-cdma
will removing peep break anything? also, is peep 'HtcTwitter.apk' in /system/app?
edit: anybody know whatever happened to the patch flipz was going to push to updater to remove peep/friendstream?
anyone? I think i may have tried to remove peep previously as I can't find it now, and my facebok for htc sense in this rom is broke? could this in any way be related to peep?
further, if I just reinstall 2.3.3 on top of the existing 2.3.3 do i need to wipe data and if not, will all my programs settings remain in tact? i just wanna fix facebook for htc sense as i like it more than vanilla facebook.
PUHHHHLLEEAASSE help me... if i was a chica, I'd give a reach around. :eek:
Lol to my knowledge peep is okay to remove, ive done it before and didnt notice any problems, but I don't use twitter at all. And facebook is broken for htc phones, just give it time.
thanks, there is a rosie/htc sence flash image for this rom, correct?, i swear that i saw it in somebodies signature, but i cant find it now.
i think im gonna wait till this rom is 100% working, b/c many other friends say its buggy on their phones, so any estimate on when this rom will be completely finished?
Until then, is there an overclock kernel/image i can flash on my phone, running sprint 2.1 (.5, not .6) RUU, & already has a custom recovery image & rooted., like any of these [KERNEL][7/22/10]Darchstar's Overclocked Undervolted kernel for senseUI roms vUV 2 - xda-developers
once you've flashed fresh or any other sense based rom you can flash one of these kernels to overclock and/or undervolt, that's what I'm doing now and it works great.
so which one should i use, b/c im running the stock Sprint 2.27.651.5 RUU not the 2.27.651.6 RUU, which he says they are based off of, b/c i dont want to brick my phone, & i want to stay under 710mhz
I suggest using a Rom based on the .6 update as I find them to have less lag. I'd reccommend either of nfinite's roms or fresh 2.3.3, all of which are easily overclockable up to 768mhz.
i dont want to use the .6 update, b/c its patched so it cant be rooted, & want to stay w/ the stock sprint 2.1 (.5) RUU until a good froyo is released, i just want a overclock kernel that will work w/ my current stock rom
^Running a ROM, such as Fresh 2.3.3 is really no different than being stock.
Joehunni is referring to ROM's built off of the .6 update and NOT the .6 update on a stock phone. You will still retain root with a ROM built off of the .6 update. :)
Unfortunately, I'm not fluent enough with kernels to know if they'll work with you being rooted and not running a custom ROM.
^^ lol thanks for that. To my knowledge, you cannot simply flash an OC'ed kernel over the stock rom, I could be wrong but it sounds like it just shouldn't be. I'd suggest flashing Fresh 2.3.3 as it is just as stable as the stock 2.1 but with goodies like friendstream. This is also deodexed and zipaligned which helps it overall performance-wise and allows for custom mods.
thanks, ill just wait for a froyo rom then
FB for HTC Sense FIXED, at least for me... don't know if it had anything to do w/ that employment info fix (i don't think so), but all contacts syncing now.
