I downloaded this a few hours ago and have been searching google and this forum to no avail. Newb quesstion is how do I install this? I rememver rooting my phone before but don't know if it still is as I did an OTA update I think a few weeks ago. Is there a guide to install this? Currently I am running 2.27.651.5.
Just download the rom zip file, put it on the root of the sd card (not in any folders), turn off your phone, boot to recovery by holding the home button while pressing the power button, wipe data (factory reset) and dalvik cache. Once you've wiped those both, go to flash zip from sd card, find the rom zip file and let er rip. Make sure the rom zip file is on the root of the sd card though or you wont be able to find it from the recovery menu, also because otherwise you'll have wiped everything and lost all your info for nothing, good luck.
After locating the zip file using Linda File Manager I opened the zip and also extracted it but neither did the install. What is it I am missing? Could it be because I somehow unrooted my phone?
That's not the proper way to install it. You need to leave the file as a zip, and it needs to be on the root level of the SD card. Then boot into the recovery mode, by first turning off the phone. Then hold down the home button while holding the red "power" button at the same time, unitl you see the black screen with the green writing. Then select backup/restore. Make a nandroid backup. After that is finished, select wipe, and wipe both data and dalvik...then select flash zip from sd. Next, reboot and enjoy your new rom!
All this is based on the fact that you are rooted. If not, go HERE and re-read the procedure to root your phone. Let us know how it goes.
I just flashed this rom and it still has the original lock screen, but it is listed with the vanilla lock. What's up with that? Is there something I missed, or can I just flash a vanilla lock screen onto this rom?
you have to go through the Fresh Updater to get the vanilla lock, he has step by step instructions on his website
I have flashed this ROM by itself and had no problems but whenever i try to flash the OC kernal in this thread [KERNEL][7/22/10]Darchstar's Overclocked Undervolted kernel for senseUI roms vUV 2 - Page 14 - xda-developers. it doesnt seem to work. I take the .zip file and put it on my sd card than go to my recovery and flash it and when i reboot I will sit on the white HTC screen forever. If i dont flash the kernal I got no problem loading up.
