what's good battery life to you i.e. best batt life you've ever had?Running it straight up. I think it is preset to run at 768.
i don't see how that overclocked kernel can give you better batt lfe than stock. I ran it twice, once by itself, and flashed again and used both set cpu, and then oc widget. battery life was atrocious.... even when I underclocked w/ max to stock default, it was worse than whatever comes loaded with fresh 2.1.2 or this 2.3.3, I won't even bother again if somebody claims to get two weeks of juice out of it. i simply can't subscribe to that snake oil
I could never get a full day out of my phone with any other ROM and especially not stock. My battery used to die around 6 or 7 o'clock in the evening. I use my phone all day for business calls, email, and web access. With 2.3.3 and the overclocked kernel at 768, I still have over half the battery left at the end of the day. I also have a lot more free memory with this ROM. With both 2.1 and 2.2, my phone would lag and the free memory would drop to below 30.
Also, I did a FULL wipe of everything on my phone. Wiped, wiped, and then wiped again.
No snake oil here, just sharing my experience.
Same problem here. There was some lag with 2.1.x, too, but not as bad as 2.3.3.For some reason, I am getting lag when placing a call using a Shortcut Direct Dial. It takes at least 5 seconds to actually dial the number. In the previous version of Fresh, it was almost instant dial. I'm using HTC Hero on Sprint. Any idea what would be causing this?
I'm new to Android, so forgive me if this has been covered somewhere.
Ok, I believe you guys, just is bizarre is all. I never ran ZenROM as it just seemed to hackneyed to me, but the OC kernels just haven't been good to me. I am tempted to get it yet another go based off your testimony. Rolling on 17 hours unplugged though, and I have 61% battery remaining, though haven't used the phone that much. I have though found other quirky behavior with this rom. sometimes, the dial pad won't come up in a phone call, say when am using a call automation system.No snake oil here also either. I am constantly amazed at the battery usage of this rom/710 kernel/OC Widget combo. Best I have ever had since day one in Oct 2009. And the rom just works smooth and fast. I was using ZenROM and had realy bad battery life... I started carrying my extra battery around with me, but with Fesh 2.3.3, that is no longer needed. Possibly because the 710 OC kernel has some memory tweaks in built into it.
Once the video camera issue is fixed i will be flashing this in a hurry.
i'm thinking maybe he posted to the wrong board and is talking about the new froyo rom.I tested my video camera this morning, and there were zero issues.
Same here, wiped everything, flashed 2.3.3, ran great for a day, then all heck broke loose. Phone went into roaming where I usually have full signal, a couple of random reboots, etc... I did a nandroid back to 2.1.2 that I had set up, worked until I got home. I wiped again, reflashed 2.3.3, it rebooted once right before I fell asleep, when I woke up it was jacked up. Wouldn't even reboot without pulling the battery. Nothing worked, ended up having to install the 2.1 RUU. Stuck with that for now, at least until I get time to re-root.......Ok so I wiped everything and just flashed Fresh 2.3.3 without OC this time. Issue now is the phone has just turned off twice now on its own. Can anyone else confirm this issue? Much appreciated.
-Drumsbh
had to remove the oc widget..made my phone pretty fast but battery drained tremendously! didn't fully charge my phone last night..had 45% at 1:00 am and woke up this mornin at 9:30 am with just 42% left..now that's wha i'm talkin bout!
How did you set OC Widget up? It makes a big difference.
Don't even remember..what are yours?
I had it set based on what was said in this thread I believe
I have mine set at 710 (max) 245 (min) with screen on, 480 (max) and 245 (min) screen off.
Different freq Screen off=ON
Use your Frequencies=ON
Auto start on Boot=ON
Then SAVE
Problem is though, I have only wiped once (no toilet jokes please)...
Do you have the darch kernal 710? How is your battery life with these settings?
I have tried and retried to get titanium back up working, along with busybox, to no avail. Will have to reinstall all my apps, not a big deal I guess.
Problem is though, I have only wiped once (no toilet jokes please) and I cannot recall if the calendar retains all the information already stored. DO NOT need to lose that info.
1) will that info hold AFTER a wipe
2) in not, any OTHER apps out there that will
Thanks a lot
Might just be me or something I did, but the stock HTC alarm clock will not stop buzzing unless I restart the phone after it goes off. But besides that, love the rom!
