Any one flashed this rom over a previous fresh rom? I'm using 2.0d, would it be ok if I flashed this new rom over it? Anyone had success doing it this way?
did you flash the Vanilla lock screen? if you did, you also need the vanilla clock and have to set your alarms in that. the HTC clock can not be used with the vanilla lock screen for that very reason.
OKAY HERO USERS HERE IS THE BIZ!!
After using the new ROM 2.3.3 for almost a week now, I personally have not experienced any upgraded performance over the previous. With regard to Battery life, which is certainly a hot issue, I have not seen the increase like others have. In fact, it seems that it has decreased a bit. I'll admit that I use the wireless tether app at least 2hours daily, but the most I can get from a single charge is 7-8 hours before I have to recharge.
When I first flashed the ROM it seems that the LAG I experienced before was decreased, but after a few days it was back to the same way it was before. When sending text MSG especially, the LAG is awful.
I congratulate the one's who have upgraded and got better performance, but as for me.. seemingly no change what so ever!! Take care forum & I hope a new ROM drops pretty quick that will help my HERO!!
....Regards
....Regards
I suppose ill give this rom a go. Does anyone know if this rom has friend stream in it as well?
i just flashed 2.3.3 but what is sprint zone? how do i get rid of peep and friend stream?
yep.. there are several radios to choose from... try them all and find the one that works best for you.. Radios Geek For Me – Sprint Evo 4g & CDMA HeroI think the reason my battery blows is because my service isn't as good for some reason... is there a radio I could flash?
