Fixmy59bug
Just last week I changed from CM6 to Fresh 3.3.0.1
Reason being I started having random lockups, the screening staying black upon "waking up" with only the notification bar showing at the top, and half of the screen disappearing in landscape mode.
I was, shall we say, less than impressed by CM6, so I figured I would try something new.
Now, I am having a new problem. Upon entering my car, the bluetooth will connect, then after about 15 seconds will disconnect. If I go into "Devices", the car kit will say Paired but not connected. If I click it, it will not connect.
I never had this problem with the stock ROM, Unrevoked, CM6, or another ROM I had that I forget at the moment. Fresh 3.3.0.1 is the first time.
I LOVE the battery life compared to CM6, but I need my bluetooth to work.
Any ideas?
Any ideas?
