ohh ok. i thought Fresh rom is a one click process. i was trying to follow the guide starting from here:
Once you have read though all of the above, you may decide that manually rooting is something you would like to avoid. If that is the case, you can do the one-click/auto root option as described below:
One-Click/Auto root your phone:
There are several auto rooters out there, but I have found this one to work the best:
Fresh Pre-Kitchen 0.2
So what is it and how do you use it?
This is a Windows application that will allow you to root your phone very easily. It basically does all of the steps for you, that you would normally have to do manually. This program does require the .NET Framework, make sure you have it installed and if not, get it installed.
Please follow the instructions below:
Step 1: Download
Pre-Kitchen 0.2. Unzip the files/folders.
Step 2: Download the auto-root fix
here. Unzip the file and replace your existing fresh-pre-kitchen.exe (the one you just unzipped above) with the one in this zip file.
*Note* Make sure you close all copies of kitchen that you have open already before doing this. *Note*
Step 3: Plug your phone into your computer and make sure USB debugging is on. DO NOT Mount the SD Card!
so you're saying i still need drivers when the guide does not say. correct?
thanks for the replies.
