When I click on the nandroid backup my the process starts, then i think the phone goes to reboot during the process (I assume this is part of the process?) then I get a error icon on my phone a Triangle with a exclamation point in the middle, then I'm stuck, the phone wont reconnect to Fresh Kitchen. should I use recovery to fore reboot? help?
One thought, do i have to use the USB to micro USB that comes with the phone or can I just use a standard micro USB to USB that I always use (the one that came with my digital camera)
thanks
Brendan
thanks
Brendan
Anyway, just wanted to add that if you have a problem where the Kitchen fails to root your phone, don't despair. You can still use the manual method, which IMO is much easier anyway. Before you do the manual method (if needed) read the entire manual root section of the guide several times to get familiar with it. Then just copy and paste!
