Root Fresh Stuck in Boot loop
jmtz345
hi im not sure if it is on a boot loop or just frozen but my evo just stays on the white htc evo 4g screen. i was running fresh 4.3 beta and it was fine. i then upgraded to beta 4.4 and then this happened, yes i did clear everything
Can u get to recovery
Have u checked the thread for said rom... to see if any one has had same issue....also what exactly have u wiped in recovery... any rom I flash I wipe cache, delvic, and factory. Then I flash a format all zipper a couple of times
Well the only thing I could say is check the thread .. or check the log on your SD card to find.out what went wrong... but that is above me u will need someone like evomattic or akazabam extreme or maybe ochbrez....one of them might chime in tonight. All of them will answer tomorrow... it is kinda late.......your best bet is akazabam that dude can fix just about any thing
weird because i flashed fresh 3.5 to get my gps fixed for cm7 and it got stuck there for like 15 min. i just pulled the battery and rebooted and it worked. so you can also try that as well. but yeah like beastinbolts says booting up especially for the first time on a rom can take a bit before it loads up.
I have had issues flashing Sense roms especially any of the Fresh versions with getting stuck. Battery pull seems to fix it then no issues after the first boot.
