cajunjacket
What's the difference? Do you have to overclock with Fresh Toast 2.1? It seems like Fresh Toast 2.1 is less stable than Fresh 2.1.1, so should I just stick with Fresh 2.1.1 if I want a stable system?
I have been running fresh 2.0d for a few weeks. Phone was wiped and then flashed with Fresh Toast 2.1 this morning. It has been running most of the day, and, even with the overclock widget, it has been very laggy.
Just downloaded and flashed Fresh 2.1.1, and the phone is back to its snappy self. Maybe I did something wrong, but I like like Fresh 2.1.1 better.
Did you install OC Widget as it suggests ?
This one?Speaking of live wallpapers, where can I get my hands on that fancy rainbow-looking wallpaper that they keep showing with the EVO. I saw that there is a static version of it in the wallpapers included with Fresh 2.1.1, but I couldn't find a live version of it.
This one?
If you think you type fast now, try Swype and stop typing. Just go blazing fast by tracing. Search and you will find the latest thread to download the Swype apk.Just went from Fresh Toast 2.1 to Fresh 2.1.1 and really liking it. Fresh Toast was super sweet and super fast but would lag out once and a while. Fresh 2.1.1 seems really solid. Keyboard is smooth (I've never typed so much in this tiny keyboard) and the rom's size is impressive.
If you want to tweak and tweak try out Fresh Toast. If you need solid (simply where I am right now) Fresh is the way to go. Either way.... you win!
Sent from my HERO200 using Tapatalk
don't worry about that... if you get used to swsype, then you can instantly use shapewriter. in fact.. download shapewriter from the market. it's free. My wife prefers that over swype.. I prefer swype...but shapewriter is still better than stock
OK am I the only one who doesn't have voice to text in 2.1.1??
I've been running Fresh Toast for a couple days now with no issues. It does seem to get hung up sometimes, but in general it's much faster than any of the other 2.1 ROMs I've tried. The speed difference is especially noticeable in 3d games, which are actually playable now, and in the live wallpapers which now run super-smooth, even though they still don't stick. That being said, some people are having problems running it overclocked, it seems as though there are some variations between processors among our phones, some where just made better than others.
My first few days I discovered that the mobile connection would just drop sometimes too. So I pushed the power button to bring up the choices for turning off the phone, airplane mode, mobile network on/off, etc. I turned mobile network "off" then back on again to refresh the connection. During this time I was fiddling with the phone a lot by adding and deleting apps I was trying and messing with settings too. After I stopped that and just started to use the phone as usual things stabilized. Now I have run the ROM for many days and have not lost the mobile connection since.The only thing I've noticed is that my data turns off occassionally (I won't see the Evdo at the top and will have to toggle my mobile widget off then back on, which is something that would happen fairly often with my phone and 1.5 as well).
