froyo is finally out!
H
hajj_3
Guest
its finally out!
2.24.161.1 (56.22mb)
i have a uk wildfire from vodafone btw, i haven't debranded but the only branding was the boot logo so i THINK its unbranded by default.
At long last...
My sim free/pay as you go phone is downloading it as I type. Had to manually make it check for the update though. (I'm in the UK)
Antony
no improved video resolution unfortunately still 352x288. Things are quite a bit smoother.
Market is the old version but once you restart it or restart the phone and let it sync it will update to the version released a few days ago.
It takes about 30secs longer to boot :( I've tried rebooting several times so it wasn't just the 1st reboot which was slow :(
Well the update went ok I suppose.
I got loads of error messages about calendar and Sync programs failing, force stop etc.
But after some searching about online I tried clearing the cache for calendar functions, Gmail and so on as per this thread:
com.htc.bgp - Android Forums
And restarted the phone, all was well.
Reception seems to be better as well, but maybe that's my imagination.
I don;t know if it's any faster yet though, we'll see.
could someone see if "linpack for android" was out for android 2.1, it wasn't a few weeks ago, just checked now on 2.2 and it is, its an app for benchmarking, if its out for 2.1 we could see what the improvement is.
its 38.67-39.03 secs for me on 2.2
No update :-( is my software versions correct ?
will i get it
see picture :-)
I don't know if you'll get it from that information.
I can say I had to check manually to get it via Setting, phone unformation, check for update.
Also, I had to do this a couple of times for it to pick up the update, I checked at 8am this morning and said no update.
I checked again at 9am and it picked it up.
My phone is with Vodaphone, but unbranded.
Do you get any branded logos when it starts up?
What phone provider are you with?
Perhaps.
If you mean you have rooted your phone, I'm afraid I know very little about that sort of thing. You'll have to wait for someone with more experience with rooting phones to reply.
its ok im debranding again with goldcard method as i didnt do this before lolz see what happens and see if i get an update in the next hour or so :-)
how do you know if your phone is branded or not? I know it sounds stupid but... When I bought my Desire (Orange FR) there was a bunch of Orange stuff on it so it was pretty obvious that it was branded. However on my (gf's) Wildfire, that I also bought on Orange FR, there is no orange apps at all so I don't really know...
Just downloading on O2 now, yipee!
Cyanogen has been good to me over the past few weeks, but i'll be glad to see the back of the occasional crashes i've been getting. :)
hey ....i live in egypt africa....thinking whn will it get here..@@
but can any one tell me do live wallpapers work on htc wildfire now ...?????? :)
Still updating and am stuck on a screen with a little Android fella and an exclamation mark above him, been on this screen for past 20 mins or so now.
Did this happen to anyone else?
I don't remember seeing that myself.
I remember downloading the update, which took 10 minutes I guess.
Then it was on an install screen for a while (similar to the downloading screen), restarted, then another screen with an arrow with a circle around it and a progress bar.
It Sat on that for a while and restarted again.
Then the next time it restarted it errored on some sync errors.
After clearing some cache for exchange mail and gmail I restarted again and all worked fine.
I'm guessing you've had some sort of failure.
