Root {Froyo Rom} | MicroFire | micromax a60 |
akash akya
Hi guys....... "MicroFire" my first rom name.....
its based on Rohan's Freek v1 which is stable & fast....
now i'm want to share it with all of u..... :)
lets move on to FIRE world,,,,
here i only mentioned few features.... all basic features are there
Features:
1.ICS theme
2.Transparent power control widget
3.aroma installer for speed flash (creadit ->varun)
4.Increased volume for out speaker and headphone
5.semi transparent menu for all app
6.colored settings.apk
7.Added "sound output & input" menu in setting (it was not in Freek v1 rom)
8.Added more network tweak for speed browsing by me
8.transparent contacts.apk
9.Gapps preloaded
10.Vedio acc & increased camera capture speed
11.New bootanimation
12.New MicroFire Poweroff screen
13.smooth touchscreen tweaks by me
14.Increased battery tweaks by me
15.
16.
Check out ur self....!!! ;)
Link:::
link is removed....
try microfire 2.0 ::::
XDA Link
Download the rom place it in sd and flash in rcvry......
New buddys download nandbackup extract it twice flash using ADT... need more help search in Thechfreek.com....
Note : More themes will b added soon.....
CREADITS::::
*Rohan for his suprb rom which i used as base
*Varun for is awsom framework ".png"s & aroma
*Google which turned me from 'noob' to this level
*Me ;)
Guys Plz commnt on this rom.... Giv suggestions....
review needed Plz......
Hit thanks if u want me to keep this work..... :)
The MediaFire link says that the file is Private and cannot be downloaded until you're the actual owner of the file.
So, please update the link.
