Root Full 4G signal but Data not working?
Being that so many people are having issues it's definitely on metros side. When they expanded the coverage back in February, i remember going through the same thing but my house and work were outside of the 4g area and after the expansion it covered both so i didn't care haha.
Maybe with this new upgrade I'll finally get above 2mbos at the house. Atlanta gets 5 but I'm 12 miles South.
Cursed out metro corp. Not even 1hr. After saying I'm dropping my service got a call from metro explaining why I lost 4g and the quick reply was network increases and ota tests not update test but what phones are on 4g and bandwidth use
Well I'm back up and running
To say the least
Firstly, sorry for punking out on you, CR...got a flood at home + no internet at both work and on phone...no nearby wifi...out in the boonies.
We can hook up early tomorrow if you wish.
Ok, i was doing fine on LD rom, no tweaks...but browsing with multiple tabs was slow....
so I (wiped caches) flashed Broken Out(which never saw any data issues in the past), rebooted, flashed the following tweaks right after:
ICS Tweak, Smooth Scroll(broken out), Ringtone Notification Pack, Universal Adrenaline Shot, Voice D&R.
I'm pretty sure i did NOT flash Update Speed 4096 OR Uncenter Clock....but not 100% positive.
FULL 4G SIGNAL, NO DATA!!!
I did not look in between reboots to ascertain if data out after rom n before tweaks(wasn't expecting it), but i doubt just the rom itself would cause that.
I could not fix right away, so endured this about 12 hours(tried the usual toggles to no avail)
I wiped caches and flashed over previous rom to no avail.
I had to factory reset, then reflash to get data back.
I'm not too keen on sleuthing each tweak, it's my work phone and need all call logs & messaging intact...it's not that risky, but all the processes just take too long.
So, to recap...'removing all the previously-mentioned addon tweaks/mods, restores data'.
Of course, removed them by factory reset and reinstalled rom.
Now confirmed twice on two different roms, LD n MT's.
fyi Right now on the latter, Broken Out.
PS...So there's about 5 addons potential culprits.
No themes involved in any of this.
I may get brave and add a tweak at a time...or anyone feel free to do so...maybe we can eliminate until we pinpoint which...
Im pretty sure Ldrifta removed those tweaks from #2 for a good reason. Soooooo just don't use the tweaks. Flash #2 and leave it alone.
Broken out was built on a different framework so that's prolly why your having issues with the tweaks. It's like mixing zvd roms on b version phones.
