LGMS690_MetroPCS_EasyWiFi_V4.0.90.apk = Easy Wifi
Also as an FYI...once I removed the MetroPCS Easy WiFi....my battery life has suddenly increased.
Easy WiFi does scan for networks, but it logs you into them too. The difference between this and standard Android WiFi is that Easy WiFi can log you into networks which normally need you to start the browser and click a few buttons (like Starbucks). It does thousands of these automatically. Plus if you have a real account with a WiFi network (like AT&T, TMobile, or your university) you can add your username and password and get automatically logged in at those locations too.
Easy WiFi will test networks it sees and connect you to them if they work well and give you a better data connection. Otherwise it disconnects WiFi and you stay on cellular.
The idea is that you get a good experience. However, if it's running down the battery, that's not good.
I also took easy wifi off my phone and it still does all that. I have wifi accts at three different places and after i initially put in my info it logs me in every time i go to those spots. it has also remembered a few free spots from random places I have visited.
Here is a list so far of what I have delete off the phone. You should try to use android mate or root explorer to copy off the files to a sdcard for backups
MVC.MetroPCS.android02.apk = Virtual Card
MobileBanking.apk = Mobile Banking
MobilePosse.apk = MyExtras
SNS.apk = Facebook for LG, Twitter for LG
Boingo_Wo-Fi.apk = Boingo WiFi
Mocospace-1.2.4.apk = Moco Space
Uno_Demo_LG_MS690.apk = Uno Game
PGA_Android.apk = Free Games
MPCS-MobileIM-0.4.24.2.apk = MobileIM
PEX-3.1.1.1-metro-rc.apk = Pocket Express
z7-android2x.apk= Mail@Metro
As I said in this post:
http://androidforums.com/lg-optimus-m/227036-new-lg-optimus-m-ms690-root-achieved.html
SNS.apk is the only one that doesn't reinstall correctly.
cat /proc/mtd > /sdcard/PartitionTable.txt
Can some one post this phones partiton layout.
Open terminal on phone, type:
Open up a file manager and open PartitionTable.txt with it's editor and copy the contents (highlight the words) and paste it here for future developement of this phone.Code:cat /proc/mtd > /sdcard/PartitionTable.txt
The purpose is to extract a full system.img for a complete backup of the phones original rom as requested from the OP.
i now have the list but i cant figure out inside root explorer exactly how to delete these files
