http://www.youtube.com/watch?v=DVORX-ZFblA
Hope you guys enjoy the video, if anyone needs a tutorial I will be making a video on that soon.
Its not doing any harm to the phone. My battery life surprisingly is still really good, don't see much of a difference. The real difference comes in emulators and applications. I've had it overclocked for 2 days now and its ridiculously fast. Everything loads instantly and its consistent.did nenamark1 on my stock G2. got 32FPS. while 35 is a 3fps increase, its very minute. I'd like to see someone actually overclock the GPU and the GPU only in a phone. I bet its just a matter of time.
Me i personally wouldnt OC the phone to 1.4, but maybe to the processors original clock speeds of 1ghz.
from what i read the cpu in the G2 is underclocked to 800mhz
Is there any progress with underclocking? My G2 is already "stupid fast," I'd rather tone things down and get a better battery life and cooler run temperature.
Not to say that overclocking isn't nice, I'll try it sometime, but I wouldn't want to leave it like that for day-to-day use. At least not as high as 1.4ghz.
Correct, you can underclock it with SetCPU. You don't need to overclock to underclock.I think you can underclock just by getting SetCPU and setting it lower.
go here
T-Mobile G2 Qualcomm 1GHz MSM7230 CPU Confirmed | WorldTech24 | news 24h
scroll down to here
T-Mobile G2 Not Fastest But Comes with Flash and Android 2.2
If you were hoping the new T-Mobile G2 smartphone was going to be one fast device as T-Mobile has billed the G2 as
Ok, so what? CPU speed isnt everything....
If you do a bit of googling..... stock speed (800 Mhz) quadrant tests have consitently higher scores than a Nexus One which is 1 Ghz fyi... u know why? because G2 is using an updated SCORPION chipset which is a much more efficient than Snapdragon 1 Ghz... the core nm are close @ 45 nM ratehr than 60 nM in the snapdragon..... please do some research.... engadget/phonescoop douchebags dont know shit... they only write these articles based on what they SEE not what they RESEARCH.....
and I stand by T-Mobile... when they say
Sprint's WiMAX maxes out @ 6MBPS, which doesnt even come close the T-Mo's HSPA+ (14.4 for now but will go upto 42 MBPS in future)(once again if you google test results you will come to know....)
Thanks
and I stand by t-mobile when they say “the fastest smartphone experience in America”
so the 1ghz or 1.42ghz overclock..what happens when you have to reboot your phone?![]()
