G2 Touch Wifi Troubles
Datastorm
I have a G2 Touch with Cyogenmod 6.1.0, and my wifi is not working. I try and connect but it never obtains the IP. It worked fine before I flashed the ROM. The router is a BT Homehub2 with WPA2 encryption, I tried resetting the hub but no joy. Also I have tried FXR WiFi fix and rescue but still have the problem. Help ASAP would be appreciated.
You do have a nandroid backup of your previous ROM to roll back to, don't you? ;)
Wireless issues can often be caused by changes to the kernel, so it's worth checking the CyanogenMod forums for reports of problems from other Hero users.
