Root G2x screen resolution mod : 190
Outlaw71
Android Expert
What's up guys, found this over on XDA forums and figured I'd port it over here. This is a build.prop mod that's easy to do, and makes your device look higher res (IMO). I used to love setting my DX to 180, but it couldn't handle it and would random reboot if I left it on there.
I've been running 190 on my G2x and it's flawless. So here's the instructions...
U need Root Explorer !
1) Open root explorer.
2) Go to system
3) Open "Build.prop" (long press on it>open in text Editor)
4) Almost at the bottom u will SEE this: ro.sf.lcd_density=240
5) Change 240 on 190
6) Close and save.
7) Fix permissions. (better do it in "rom manager")
8) Go into 'SpareParts' and uncheck 'Compatibility Mode
9) Restart your phone.
For all you visual people, here's a video I made for you...
YouTube - LG G2x 190 screen resolution mod...
