Root Galaxo Theme Help - Phone Wont Boot!
Hi, I just tried to load the GalaxoSense Theme to Galaxo 1.6.1, and now my phone wont boot. I'm in the process of flashing with Odin, and I'll let you know how that goes, but what is the proper proceedure for applying a theme?
I got the theme from here
I've tried theming 1.6.1, same thing happened to me. I don't think you can use cupcake themes on it? but flashing with Odin always works.
Alright, so I figured out that the theme was not compatible with 1.6.1, found one that is here.
So now, I got everything working, but can't connnect to the market through wifi... which makes things difficult, because I don't have a data plan.
Is anyone using a theme with 1.6.2? I've tried 3, no luck, phone gets stuck in boot.
for me works the galaxair theme (i have got 1.6.2 galaxo).with galaxsense or darkmix my phone could`t boot.
certain advices: before you try to install a subject make first nandroidbackup (
important!!!!!).
if you see that you have problem in the boot, you remove the battery and put again in the phone.you begin in rekovery and make restore nandroid backup.
I tried these themes from the above site... it seems they only work with 1.6.1. Darkmix theme does not work on 1.6.2... according to the source -> [th
