YES!!!
Angelo and Martz are out!!
Yahooo!!!!!!!!
YES!!!
Yahooo!!!!!!!!
While on the subject of gaming, do I need to play the earlier Elder Scroll games to understand Skyrim? Or will I get as much out of it going in fresh?
Moral of the story: use wireless where trusted, especially in the places you spend a lot of time (work/home). Turn the wi-fi setting on and forget about it for much better battery life. A 4G/wifi solution works fine by me, and espite having unlimited data, I'm OK with leaning on wifi networks for the added time between charging.
YES!!!
Yahooo!!!!!!!!
Not sure if this was answered yet? I never played the other games and as far as I can tell I'm having no problem playing Skyrim.
Yeah, but what if you get Spagnuolo?![]()
I got out of work early today because a case got continued.
Been playing Skyrim for the last two hours and I am HOOKED!!! Playing it on my new laptop at high settings, and thank goodness it's smooth as butter.
But this game is awesome! Such detail, so many things to do! And the story is pretty good, too.
My Gnex and modding has actually been pushed to the side for the time being.
My dream is for them to bring in Polian since he's out at Indy. Don't know who will be available for the OC position.
I'm actually happy they're keeping Lovie onboard. He's done a lot with such little talent.
I just can't believe Norv Turner didn't get fired in SD.
OK, here's a quick and simple test between Galaxy Nexus' stock camera and HDR Camera + App. actually the stock camera is not doing a bad job. The HDR of course is creating a more evenly lit scene and is popping up the colors and contrast a bit. Stock takes the pic in an instant, HDR will take a moment or two, not too long of lag.
I find myself taking ALL pictures in the stock app and then modifiying them in other apps (Vignette, Camera Zoom FX, etc).
Can you do this in HDR Camera or it needs to take multiple exposures the first time?
glad hdr is working well for you...it definitely made a world of difference. Haven't figured out how to use zoom and take video with it though. I disabled stock cam since its a potential battery leak. The other cam I have is zoom fx...don't remember if I can take video with that one either
