H
HanSolo
Guest
While on the subject of gaming, do I need to play the earlier Elder Scroll games to understand Skyrim? Or will I get as much out of it going in fresh?
Was wondering if anyone new of an app that that can be used to create a widget that will perform multiple tasks? For example, when I go to place that I get little or no signal but can connect to wifi I will turn airplane mode on (with a widget), then turn wifi on (with a diff widget), then in call settings I check the "receive internet calls" option (use google voice and native SIP integration). I'm wondering if anyone knows of an app that would allow a single toggle widget to accomplish this all in one???
Thanks for any and all help.
is there an outage on verizon today or something? I flushed the new radios and gummynex yesterday through cwm and 24 hours later, I have no 3g. 4g works fine but 3g says it gets a good signal but the bars stay gray and no data. Any suggestions?
Have you tried flashing back the older radios to see if it corrects it?
not yet...trying to do a little research first...would you suggest I try that? I was actually thinking of flashing the new radios again.
Something that was posted a a few days ago about the camera was instead of just tapping the button to snap off a quick pic is to HOLD your finger on the release button till the camera focuses and then release the button.
I would flash the older radios and test out your 3G. There could be a 3G issue in your area who knows. I wouldn't try flashing the same radio atop one another. With the Inc, although quite different, flashing the same radio twice could brick the phone. I don't know what it'll do to the GN![]()
well that's good to know, haha, glad i didn't try that. what about something less drastic first, like pulling out the simcard? could that help reset it? In the status it says eHRDP:13, in service, and either connecting or disconnected. Signal strength seems good. it looks as if it is on 1x but thinks it's on eHRDP13
anyway, how would I pull out the simcard on this thing? I've always had verizon, this sim card stuff is new to me.
Having a little alarm problem -
After your alarm goes off if you accidentally leave the alarm screen the alarm just keeps going off with no way to get back to the screen? What am I missing here?
it should show up in your notification bar. Pull it down and click and it will give you the option to snooze or dismiss.
You got the 4.04 update? I wasn't aware that 4.03 had been officially released yet.
Did I miss something?
Good morning everyone -- happy new year!
Took a break from the internet for the past few days, just basic stuff on my phone, but really didn't jump on any forums. Wanted to hang with friends and family to start off the new year and it felt great to get away for a few days.
Back at work now and looks like we're gonna have a real busy year.
Hope everyone is well -- missed you all!
The radio on this thing is really starting to get to me.
Where I sit at work has 0 bars of service (sits at -120dBm sometimes) and my connection times out such that when I do get to an area of service I have to toggle airplane mode sometimes for it to work. I just wish they would move my desk (unlikely) or fix this radio or something.
Grrr.
