tluley51
Are you sure you downloaded the right keyboard apk? There is a Latin one and a different one, and I know one definitely doesn't work with 4.0.3 roms.
Yeah there is LatinIME and LatinIMEGoogle...with this rom/theme it runs on LatinIMEGoogle. It is the one specifically for the theme/rom so it is supposed to work.
Tell us the exact steps you are doing after a wipe... And I'll flash the mods following your steps and see if I get the same problem
Ok after wipe of data/cache/dalvik I loaded Codename 1.1.1 and kejar's gapps and booted the phone. Then rebooted into CW and flashed the theme and booted the phone. After seeing that everything was fine, I first tried to rename the original LatinimeGoogle.apk to LatinimeGoogle.bak and extracting ONLY the .apk from the .zip that is included in the theme thread and copy pasting the .apk to the /systems/apps folder. Since I get force closes with that, I rename the original back to .apk and delete the themed version and boot into CW (after a nandroid backup of course) to flash the whole .zip folder. Still force closes and then load the backup so I am running themed Codename 1.1.1 with stock ICS non themed keyboard.
Need anymore info just let me know...I may have left something out, but I don't think I did...
EDIT: Links to everything...
Codename 1.1.1 ROM
Black and Cyan Theme
