AntimonyER
CHANGED FROM AF ADDICT MIKESTONY
May be a relationship between Android techie males and cooking![]()
You could be on to something...
What temp do you smoke your brisket at? I usually run beef around 240 and cook until internal temp of 200. Also, what type of wood do you smoke it with? Its usually apple for me. I also like to cut a pocket in the brisket and stuff it with bacon and onions and "sew" it closed with skewers. Just a few, you don't want to overwhelm the flavor.
j/k I've done it so much I think I've mastered it!I wish I had the time/money to learn how to do BBQ, because I LOVE the stuff. I make a decent rack of ribs, but the oven cooking, finishing on the grill method.
I don't do Android Development yet but I'm gettin my machine set up for it with a Linux environment. But I might be able to help ya depending on what your question is. I have a real strong coding backround with Java, C, and even assembly. What's your question?? You can shoot me a PM if you want or just ask here.
I've done the oven / grill ribs and they are excellent.
I've only been smoking meat for two years. It really isn't that expensive or time consuming. Actually, the premise of it is taking bad / tough cuts of meat and making them palatable. I'll give you two hints I've learned should you try smoking BBQ. I bought my smoker for about $200 and I am usually smoking meat that costs $1-2 per pound. And it really doesn't take a lot of "time." While my pulled pork usually takes 14-18 hours to cook, I probably spend about 1/2 hour actually doing anything. About the only PITA is getting up at like 3AM to add woodchips.
Black pepper gets really strong in a smoker. I tried the rib rub for the oven / grill ribs (which really tasted good) on ribs I smoked and the black pepper was overpowering. It was all you could taste.
I smear plain yellow mustard on the meat before I put the rub on. It is a good smoking spice that you won't taste in the finished dish and it helps the rub stick to the meat.
I love that correlation!! Should work out well for me since I don't cook. (I bake, although I haven't done it a lot since the kitchen isn't mine)
Yum! My wife requested beef brisket, smoking/low heat since morning, will serve with coleslaw, fresh sweet corn on the cob, potato salad, bread, and pulled vinegar based bbq'd brisket tonight!
Happy V-Day all <3 !!
What BBQ means, by location:
Northeast - a cookout in the backyard
.arguing bbq style is like arguing religion.![]()
bbq is certainly an art. it is amazing to me how the definition of the word varies across the country.
SC - pulled pork, mustard based sauce
NC - pulled pork, vinegar based sauce
TN - pork ribs, dry rub
Rest of the south - pulled pork, tomato based sauce
Midwest - ribs, sweet sauce
Texas - brisket/beef ribs
Everywhere else - pork or beef ribs, tomato based sauce
you'll never convince me that anything is better than SC style, but i wouldn't try to change anyone else's mind either. arguing bbq style is like arguing religion.![]()
I just took bricks and made a wall in the bottom to where you can only put about 1/3rd the amount of charcoal in and the bricks serve to keep direct heat from getting to the meat. I take two foil pans, one larger to hold water and one smaller to hold wood chips and place them over the bricks and coals. I position the lid vent over the meat so the smoke is forced to go out over the meat and I also place a meat thermometer in one vent to get an accurate temp at the meat. I start with about 1/2 full charcoal chimney and every 3 hours (give or take 30 mins) add more charcoal (about 1/4-1/3 chimney full). The only pain is you have to open up the grill, take the grilling surface and meat out, remove the pans and pour the charcoal in and then put it all back. If it's big enough, you can leave an opening big enough to drop coals in with a pair of tongs and then push them under the pans, but you still need to remove the grate with the meat...unless it has that flip up section that would let you put them in that way.It is more Android related than anything else, but take a look here: http://androidforums.com/application-development/499968-actionbar-tabs.html
I'm no expert but I'm pretty sure NC has two different styles of BBQ![]()
Best I've had in my travels (which are not many) was in Virginia. It was pulled pork with no sauce. When the place caters they send 4 different sauces for people to choose from. I skipped them all and put malt vinegar on it which then soaked into the delicious potato roll it was on.
I think I better eat lunch soon.
, that sounds good. I will often make four butts (32 lbs) at a time for large cookouts and keep them warm in catering trays. It is so much easier than manning the grill when you want to be playing horseshoes or washers.
Who would have thought we could be on our way to 10k in just 2 short months???
