AndroiDad75
So with the new Google Wallet out, we won't get it because we had to sideload on our phone, correct? Is there a way to update our Google Wallet? I haven't updated it since the first week of release.
OK. I'll go look for the trick...
I would recommend the same chief...go without the JD...and use the settings in ROM control. The only problem I have had since I got rid of JD...is when I tried to copy someone else's settings. Since each physical phone handles differently...I ended up finding a great match for my phone with LeanKernal exp versions. I also set my governor to 1650/350 and interactivex....but I honestly leave everything else stock on AOKP. I usually end the day with about 30% battery left after gaming and regular use including navigation, after about 16hrs a day....
Disclaimer: I am in a good 4g area, always leave wifi on, but turn GPS off unless I need it.
I have been having the same problem. the last three times I have had to manually go to the play store, go to all, then the wallet app, before I was able to update. updates aren't pushed to the phone anymore.
This makes me nervous. I went to enable Powersaver options in AOKP and it threw up a downright SCARY warning about it being experimental on CDMA/LTE devices and possibly unstable, causing infinite loops, etc. I opted to back out.
I'm like you Chief. Those warnings keep me from trying the Powersaver options.
Sorry Chief should have been more specific....I do NOT use the power saver functions in AOKP. I found out near the beginning of me using AOKP that I did not need JD either...as long as I had the kernal set properly, I end up not turning off data, or modifying the settings like I did with JD. I just did not need them any more. I found that I am getting so much more battery time and usage, with AOKP and Leankernal experimentals that I don't have to turn off data. But I am in a decent 4g area and at home on wifi....
I am at 19 hours plus up time right now and still have more than 20% battery left.
SO let me get this straight, Ryan: I turn off JD and forget it? Other than PowerSaver options, I don't know where to go to "set up" a kernel. I'm using the kernel that came with AOKP. I DID turn off JD so we'll see how that works...
Morning all!
For those who are afraid to try Power Saver on AOKP due to the warnings, I've run it since sometime around build 28 and had no problems other than the slight annoyance of having to manually turn mobile data back on ocassionally. It just turns mobile data, or wifi, or both off after a specified time with the screen off. I found it helped greatly at work due to poor service here. However, we now have a mobile wifi network here so I no longer use it.
So I guess this means no more suffering through slow 3G for you huh? Lucky. Although be careful, I believe they can track your usage through that
Yeah they can. It still goes through the filter as well, so I can't do much on their wifi. I don't use my phone that much anyway. When I do need to do something on it I turn wifi off and do what I need to do then turn it back on. I get good enough signal to do small things but it's apparent that it searches a lot through the day to hold that signal. The wifi just keeps the battery from running due to the signal searching.
Morning all!
