Help Galaxy note 3, IMEI lost, no network
Hello,
I have a problem. I have made an automatically update on my Galaxy Note 3 N900 model, and after that, i have lost my IMEI (it shows null/null) and i can't use my SIM card. I have tried a lot of things and nothing didn't work.
Please reply if you know any solution!!!
Best Regards
Q.
Only thing I can think of is the phone could of tampered by someone, was the box sealed when you bought it by any chance? what kind of mobile store you get it from?
if it does not work then i would take it back.....not sure how you can receive an update and then losing your imei.....it does not work that way.
did you root the phone as suggested in your most recent thread?
did you flash a rom or something before this happened? what exactly did you do? what guide did you use to root the phone? what carrier do you have?
the more details we get, the better we can help you.
Hello to all,
I have the same problem, I've porches my N900 in a different country, once I've activated my device at home I was able to call out and receive calls and once an automatic update as accrued the device reset, after that I've receive a call once I answer that call the call was dropped and I could not receive or dial out any more.
After a quick search I have notice that the device missing the IMEI.
I've try upgrade from Gealy Been to kitkat 4.4.2, and the result are the same.
the only solution that I've found to bring my device IMEI is to install a modem (a Russian version), but I'm receiving a message unlock sim code, and that code is not the one that I've receive from the store or the one that I've receive from samsung support.
Can you please help me understand what is wrong with that phone, and how do I solve that.
Hello to all,
again....you can't just loose your imei like that.
is the phone rooted? can you call the store you bought it from? i can't help you too much as i only have had cdma phones here in the US.....so sim codes are a bit out of my league.
Hello,
Best Regards
Q.
We really need to know more to go on. :)
Please type in *#1234# from your phone dialler and tell us exactly what it displays. It should be three lines displayed like this (the codes have been drawn over on this screenshot):
Also from any home screen: left soft key>settings>general>about device (bottom option - you'll need to scroll down) and tell us your model number and the Android version you have. Finally, and perhaps most importantly have you ever tried or succeeded in rooting your device or used Odin on a Windows PC to either root or install a custom ROM ?
I have an idea of what might have happened, but I need more information.
To Fix the NULL IMEI Problem only need flash this modem file with odin in modem (under down of pda)
s5.picofile.com/file/8134250126/modem_n9005.tar.html
press the red botten to download
دانلود فایل
or
s5.picofile.com/d/9e965e46-9166-4151-adc2-0fc76559d1ae/modem_n9005.tar
