Well sometimes (emphasis on sometimes) in the press shot photos the date showing in the calendar widget usually indicates the release date. If you look at the press shot that was leaked last week it had 02/14 in it. This has led many to speculate that the release date will be february 14th. But again this is all speculation.
Well, if you look at other devices with similar specs. You are looking at anywhere between $500 (which would be the absolute minimum.) to $700 (Maximum). I'm betting it will cost around $650, I would be surprised if it's any less than that.
