Help Galaxy S2 update issue
Hello there,
I'm trying to update my Galaxy S2 I9100, which has Android version 2.3.3 via Kies in windows 7 64 bit. After I connect my phone via USB I see unknow error.
I went to event viewer there i found 2 errors.
1)
Code:
Application: KiesPDLR.exe
    Framework Version: v4.0.30319
    Description: The process was terminated due to an unhandled exception.
    Exception Info: System.TypeInitializationException
Stack:
   at KiesPDLR.App..ctor()
   at KiesPDLR.App.Main()
2)
Code:
Faulting application name: KiesPDLR.exe, version: 1.0.0.0, time stamp: 0x4fbbbcdf
Faulting module name: KERNELBASE.dll, version: 6.1.7601.17651, time stamp: 0x4e211319
Exception code: 0xe0434352
Fault offset: 0x0000b9bc
Faulting process id: 0x1480
Faulting application start time: 0x01cd4eddc4e0ff8d
Faulting application path: C:\Program Files (x86)\Samsung\Kies\External\FirmwareUpdate\KiesPDLR.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: 02e33bf7-bad1-11e1-802f-005056c00008
And other thing which I found is information
Code:
Fault bucket 3000119171, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: kiespdlr.exe
P2: 1.0.0.0
P3: 4fbbbcdf
P4: FirmwareUpdateAgent.Common
P5: 1.0.0.1
P6: 4fbbbd4c
P7: 1
P8: 5
P9: System.AccessViolationException
P10:
C:\Users\Satish\AppData\Local\Temp\WER22CE.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\Satish\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_kiespdlr.exe_6734447e2a11fd191449d96cb5d7262cd68a74d_1c2d317d
Analysis symbol:
Rechecking for solution: 0
Report Status: 0
Please suggest me what should I do?
Thanks
Satish
This looks like a .NET problem. if you have .NET 3.5 SP1 or 4, try installing them, and reboot to see if that solves your problem.
I'm a .Net developer, I don't think it is problem with .Net.
I have re-installed Kies many times... but it did not help
This is the error which I see
You'll probably be able to pinpoint the problem more accurately by checking the .NET framework logs as to whats causing the problem.
Note: After doing a little reading, try changing your current Windows profile and see if that problem resurfaces.
Have you tried reinstalling the Kies drivers for the phone?
Also check if your usb cable and ports are working good.
Maybe you should contact Samsung support?
Hello there,
1)
Code:
Stack:
2)
Code:
Code:
Event Name: CLR20r3
Cab Id: 0
Problem signature:
P1: kiespdlr.exe
P2: 1.0.0.0
P3: 4fbbbcdf
P5: 1.0.0.1
P6: 4fbbbd4c
P7: 1
P8: 5
P10:
Analysis symbol:
Report Status: 0
Thanks
Satish
Hi there.
Your error code refers to a file "KiesPDLR.exe." Navigate there and look for KiesPDLR.exe.config. Open this file in notepad. You will see an XML value referring to .NET framework 4.0... delete this tag, leaving only the tag for .NET 2.0, eg:
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version="v2.0.50727"/>
</startup>
Save and close, then mark the file read-only so it can't be overwritten by Kies.
You may have to repeat this process for other files. I had to change three before I could finally update my phone.
Good luck,
Ryan
Hi, Ive been suffering from this for so many months, tried reinstalling, JVM,.NET FW.
If you look closely to the error it says .AccessViolation.
I tried opening Keis with "Run as Administrator" and voila.
Hope that helps
