Help Galaxy Y Front Lens?
TheNova
I was just wondering what the 2 littles lens are on the front of the phone, at the top to the right of the call speaker.
I thought it might of been a front camera, an LED notifier/display or a torch, but I can't seem to find any settings for it.
Are there any uses for it or even any apps that use it?
I moved this to the Galaxy Y forum, you should get some help with your question in there. Thanks for understanding. :)
Buddy that are sensors to turn off lcd during call....
When you are talking on call you will see that the screen turns off and u continue to talk..this happens when the sensor feels that you are on call and turns off the screen to save battery....just try yourselg if you want...
Eg-make a call to your own number and put your hand or your ear on that sensor ,your screen will turn off......
Press T H A N K S
