Bomberman
Any of you able to run setCPU or HTC-IME Keyboard on 9182010
SetCPU is fine for me.
i use infect's gapps and i wasn't able to download new gmail.
Ok, here we go. I want to go from galaxo to gaosp. Simple as that. Now i`m asking kindly for some experienced and long time user of latest gaosp(from when it was launched) to objectively make a list with pros and cons; what's working and what is not, what is awsome and what sucks, all this compared to galaxo. Also any suggestions after going to gaosp, like performance tweeks and stuff like that. A must for me is the camera and the market to work. I`m waiting, hopefully 2nite i`ll make the change! Thanks
i`m in romania i cant pay for apps here, and i dont have any money on my debit card atm...i would gladly pay for drakaz's work, and i will in the future. So i cant use updater.
i have the 6.4 recovery already. now i dont know what to do.....to use the gaosp beta 2 or the nightly :-?? What are the HUGE differences between this 2 and the galaxo? At least tell me this, the most usefull and functional proprieties of gaosp releases over galaxo ones.
also backed up apps and data with my backup pro...Cool man, awsome help. Anyway i knew how to flash, since i went from 1.5 to galaxo 1.6.4 going thru all the versions. Thanks again no matter what. There's just one more thing
why is so little memory, this is after a reboot, after removing all unneessary apps from startup with startup auditor.
Believe me ... I wish I had that much memory. Im stuck with 24-27
Also, if i dont like nightly, and i backup the nandroid slot 1, i`ll have my old galaxo 1.6.4 without any changes? all the apps and data?
As it is with all apps settings and everything
what happens with the nightly? just remains there in the phone not used?
No it will get wiped or better still ...Make a nandroid on slot 2. Then u can shufflle between them at wish
also can i use the darksense adw launcher from infect? or i should just instal the normal adw 1.0.1 also from infect
It has version ADW 1.1.5 integrated
I didnt try...Maybe you can tell me..Also No themes for Froyo at the moment..But will have it soon
should i rename the file " GAOSP-2-09182010-NIGHTLY.zip" to gaosp update.zip or just use it like that?
No...Just Choose apply any zip option in recovery
this was fast, it boots faster than galaxo, i`ve set the overclock to 710 and the adw on persistent...now i`m doing restoring and stuff...more testing to be done..
i love the iphone like slide unlock
i`ll need some guides about cyanogen thing
awsome till now, gmail works,youtube works, market works!!! i havent seen one bug yet![]()
can u recommend a keyboard? i noticed that HTC_IME is not working
swiftkey or htc_ime...pls any links with the one working on ure galaxy i7500 with nightly.2.0.3 - lol this thread exploded overnightWhat version of setCPU are you using ?
What's that app r3dpuma is using? I've ad it before but forgotten the name...guys there are two sets of gapps . one is of 17mb and the other is 8mb. for me when I used 17mb one the phone became superslow. now I installed the 8mb one(the one from infect's site) phone became good again. just cross check if that's the case for you..
2.0.3 - lol this thread exploded overnightWhat's that app r3dpuma is using? I've ad it before but forgotten the name...
