I have tried using USB or WiFi tethering but it just doesn't work, so can someone confirm this feature is not yet implemented/working on this nightly builds, right?
I've also tried instaling EasyTether which works well on v1.6 but it doesn't work on Froyo yet, computer doesn't recognize Galaxy.
after boot the phone goes on locked and by default the lock (side) button is diabled
try to press the end key or in some cases, this happened to me only once
you need to take the battery out and next boot everything will be ok
this symptoms may related to the proximity sensor, whenever I received a call and the proximity sensor actives the off screen event, the phone will be locked after conversation. The only solution I found is to uncheck the proximity in the "setting-> display-> proximity sensor", hope this can help you guys.
Yes you can. Make sure you use recovery 5.1.1 and of course don't forget Nandroid backup .
Yes, nandroid back up AFTER you move to recovery 5.1.1.
I have yet to find a way to restore nandroid backups from pre-5.1.1 versions using 5.1.1. The new version has a 'slot' system, which I had asked for haha. Got tripped up by my own request. Oh how embarrassing.
However, I did discover that it keeps ALL backups in the Nandroid folder - so I deleted the mistake and I was back
Everyone probably already knows, but I thought I'd put it out in case anyone else is as numpty as me
its a strange thing. Galaxo feels snappier than the nightly build. However, in linpack I get around 0,5 mflops with galaxo, but around 2,500 Mflops with the nightly build.
can anyone tell how fast this is as compared to galaxyo 1.6.3 ??
you can try to install rthunder2, a 3D game on both nightly and 1.6.3.3, you can see the difference. For the user interface, scrolling..etc, 1.6.3.3 has better performance, but when you run an app in nightly compare with 1.6.3.3, you can find nightly is more better.
