http://www.drakaz.com/2010/06/25/gaosp-public-beta-2-released/I am getting the same "passion" error as many others when trying to install the GOASP_ADDONS.
Ok guys, two questions which aren't answered by just looking at the howto:
- is there any specific release which is needed in order to be able to flash GAOSP B2 (currently have xxjb2)
- which version of recovery do we need to use, and where to find it
thanks... can't wait to try it![]()
Download it from: Multiupload.com - upload your files to multiple file hosting sites!.
The link on code.google.com is probably old.
Does anyone know if the recovery can be updated to 5 from 4.6.3 by just replacing the RECTOOLS.tar.gz file without the need to re-flash the recovery image?
You need Recovery 5 which can be found with instructions on the GAOSP site forums section.
