Root GBSandwich_V3.0.4 ROM For A75
Hey gautam.. i installed this rom and the rom is very nice :).. the only problem for me is each time i shut down the phone the battery has to be replaced to start the device again :(.. i restored the stock rom using Nandroid and installed GBsandwich again but with no avail..
do factory reset of phone... :)
Hey the problem is solved as i uninstall the apps what i have changed/added to system as per my requirements i think there was a conflict with apps and system files and the updates solve the overlapping problem as d sync icon is now made to be a arrow in the potrait mode and the usual one in the landscape mode and there is some changes in notification also check the screeines.
This is the best smooth customisable n stable ROM.
@Shahbazas : Can you give a flash for this overlapping?
Also you said you have modded to 3.0.5. I need this. Thanks in advance.
Can anyone help me??, i have installed this rom on mmx a73 but everytym when i switch off my phone i have to reinsert my battery to start it again..
Not Charging In Switch Off Mode .....
switch off problem ....
not starting automatically need reinsert battery to restart........
Here is the zip which will solve all the problem so just flash it and all the problems like Overlapping of the icons and the Not charging while in switch off will be solved and also some changes in the Notification panel which you will observe when u have any notification.
Credit goes to DROIDPM i am just providing the zip made by me for A75
GBSUpdateV3.0.5.zip
This is optional zip for those who want CRT OFF Animation but if you flash this then while screen is lock u need to wait for atleast 3sec to unlock it cos of CRT OFF Animation and after flashing it if feel you dont want the CRT OFF Animation it just flash the Above zip of 3.0.5 Update and the CRT OFF will be removed.
GBS_CRT_OFF.zip
So enjoy now without any problem
Important:
And haan the 1st zip is only for A75 as the zip contains the Boot and Logo img if you want to flash it over A73 then you need to replace the Boot and Logo img from the 3.0.5 update zip. the second zip of CRT OFF Animation can be used on both A75 and A73.
@drdogautam Please update the links in the OP for 3.0.5 update and CRT OFF Animation.
camera hangup when I click pic.....but now ok
there was problem with statusbar...
time is displaying middle of the statusbar...&when I on GPS incon display 1/4th only..because of time display in the middle of statusbar...how to solve it....
Ya that's okay as if its done so that icons should not overlap only a slight part of icon is seen next to time n if u turn ur phone to landscape mode u ll have the full icons.
I have ported a new ROM GBSandwich_V3.0.4 on Our MMX A75......
Installation process is same as another ROM via CWM Recovery....
this is the link for the ROM:
GBSandwich_V3.zip - 4shared.com - online file sharing and storage - download - subhash gautam
GBSV3 Update to GBSV3.0.5 and the Optional CRT OFF Animation. (credit: Shahabazas)
GBSUpdateV3.0.5.zip
GBS_CRT_OFF.zip
network icon/status bar disappeares on restart .......power off charging is also not working.....I flashed the Gbsupdate....it working for one restart .....
pls. help
I know that.......but after switch off need to put off battery to restart phone ..& charging problem also.
So after flashing the 3.0.5 update still u are facing the charging problem let me think...
Okay got it for charging problem in off mode go to system/media/image and delete the image folder and restart now you can charge in switch off mode i just forgot that GBSandwich has a logo image in that folder too so just do it and you will be done.
