generic rk2928 tablet was bricked
If you can figure out a way to access a recovery mode, you could try a factory reset, but if you ended up deleting a file that the system requires, you'll most likely stay stuck in the boot loop.
Try to see if you can get into a recovery mode (FYI, not all devices will have a recovery, especially off-brand devices.). It will probably be a combination of the hardware keys like holding the vol. dn/up and power buttons. Try different combinations. If you find it, you can try to reset it and then let us know how you make out.
  • Like
Reactions: mikedt
Upvote 0
It looks like you have a Teac Accord 714 tablet. Most of the information I can find on that shows me it was a model available in Israel, but that's about it. I saw a few other questions looking for firmware and recovery with no answers so I would venture to say there's not much out there for this device. You could try contacting Teac directly and see if they have a tool to reflash this that they could provide to you.
Upvote 0
Hello.,.I use BSNL Penta w707c.which is a RK2928 based tablet.,.Yesterday i rooted and it was working well,..,suddenly i thought of install chaifire 3d,..i my device is not starting after that..i have my tab stuck on BSNL penta logo everytime i start,..i tried to update firmware given on their website,.But my tab is not going into recovery mode(i think).,.My computer is intalling my tab driver as composite ADB interface bt not as RK29 device..Thast why it is not detected by RKbatchtools or any other flash tool.,.,COuld you plz help me with any solution,..,
thanks in Advance,...
Upvote 0
Can you try Volume + and connect the USB cable?
Upvote 0
Uh, Hi, Can you dump the parmaters file with RKFlashtool after connecting the tablet with Volume up and USB connect?
rkflashtool p > param.txt
I don't have any VOLUME button on my device and when I run rkflashtool from console I receive message "fatal: cannot open device"
I have TEAC logo all the time on the screen and it does not continue to boot.
Upvote 0
BEST TECH IN 2023
Smartphones
