new optimus
Android Expert
sounds good.did a nand restore for now will give flashing a ago again once i get outta work and home
its not difficult, you got the backup done, you need to copy all your sd contents to computer then in recovery go to partition menu, and create a ext partition of 512mb or so, could be less could be more depends on your apps.
make 0mb swap partiton.
rest fat32
let it do its thing then toggle usb and put all your sd card back including zip for sense rom then flash sense rom again. do a full wipe before rebooting.
