Your SystemUI.apk in the sdk tools folder is misnamed.
Change it in File Explorer.
Sorry, I'm back to my phone, output was harder to read.
I add .bak at the end.Your SystemUI.apk in the sdk tools folder is misnamed.
TWRP main window.
Mount button.
Check System.
Back button.
^Make sure that has been done.
OK, it didn't copy over.
Confirm that SystemUI.apk is in your sdk tools folder.
dir SystemUI*
Edit - you should see SystemUI.apk there, no changes to that name.
If it is, then do -
adb push SystemUI.apk /system/app
adb shell chmod 644 /system/app/SystemUI.apk
adb shell ls -l /system/app/SystemUI*
Now i need to know how to change the boot up image on Captain_Throwback ROM (if that's what it's called) to the default HTC ONE.
Anybody?
Yup.PS - despite being on a dev team once, I can't remember the standard HTC location that gives the rom boot screen.
Probably zip files in /system/customize/resource or something.
I might go mess with something... then be back here asking for help caused my phone is now permanently Bork.. lol.Yup.
I swapped the bootanimation.zip and downanimation.zip recently to the one from the old port.
If you're ever in question as to where it goes, the location is somewhere near the bottom of the file /system/customize/CID/default.xml.
The files you need to replace are in /system/customize/resource and are bootanimation.zip and downanimation.zip (if you want to change that too).I might go mess with something... then be back here asking for help caused my phone is now permanently Bork.. lol.
Cap, Is there an easy or easier way to do this ...that even I cannot mess up? Don't get me wrong, i kinda like how the ROM boot up, just that i really love to see the HTC ONE logo when booting.
By the way, did i ever tell you that i love that you brought this ROM to our attention here on Android Forums?.
Edit: I found the /system/customize/CID/default.xml --- Now how do i change or replace what needs to be done? I have both Sense 5 ROMs installed.
I hear you on that, buddy.I'll leave that to someone else. It's really simple, though - replace the existing files, set the same permissions, reboot and you should have your new boot animation.
If you use a stock One bootanimation, it'll be too big. Thus the reason I took the resized one from the old port.
Hey, you've always been extremely helpful, and that's all anyone can ask.:banghead:
Yeah.
It's always something.
I need to stop phoning in advice and start thinking before I post.![]()
As Cap said, you've always been helpful ... In fact, you've personally helped me out an a few occasions. Don't stop doing what you do best.I need to stop phoning in advice and start thinking before I post.
So - Is this the one you've used in your ROM, or the one that I should use to get the stock HTC One boot animation?Here's the boot animation zip I was referring to: https://code.google.com/p/evo-4g-lt...k/system/customize/resource/bootanimation.zip
That's the one you want.So this is the one you've used in your ROM, or the one that I should use to get the stock HTC One boot animation?
Not being a developer, or even an highly tech savvy person when it comes to rooting development, can make understanding words spoken from developers a little complicated to understand at times.
Nonetheless, I won't stop until I get this right.![]()
