Yep and ask away if his instructions for moving it give any grief.
Btw - two things to put on your list.
First, make sure that you've got Fastboot off in main settings, power.
Second, as soon as conveniently possible, test a simple "adb reboot" command (just that will be fine while running).
If you can get to it with adb, you can get to with fastboot and that's a must for extreme error recovery.
If not, fix your sdk tools or drivers or whatever right away so you can have fastboot and adb at your fingertips.
Hmmmm.
Also maybe a good idea to move this all out to a separate thread.
Stuff happens and I think we agree that what happened wasn't caused by the rom itself or anything like that.
If you agree and you're at a pc, please go for it.
