Root Getting rid of Liberty Animation after SBF
kapstone
39
4
I need to send my phone back to Verizon and I had Liberty installed. I just SBF'd and it worked fine except my boot animation still brings up Liberty. I did a factory reset and reboot and it sill has the Liberty animation. Do I have to go back and install Liberty, set the boot animation back to stock and then re-SBF or is there an easier way to do this? Thanks
you could have done it through the liberty toolbox but too late for that ....you can always reroot and use this app in the link then unroot
Boot Animation Switcher Application by n8 - Change your boot anims the easy way
Upvote 0
BEST TECH IN 2023
Smartphones
