Getting theme changer for my H7100
moarmann
I already have my H7100 rooted. I used a ROM for it called "Hardmaster" (Sorry, I can't submit links yet).
I can't seem to find any other ROMs for my device that have the theme changer feature. Would I be able to use a different ROM, or are they device-specific? How difficult would it be to add the theme changer to my current ROM?
Thank you for any help.
I dont think you can just add a theme changer, think it would have to be included in the rom (CM, AOKP) i could be wrong though :thumbup:
ROMs are definitely device-specific.
I don't know in detail what support the theme changer requires, so can't really advise on how easy it is to port. It isn't just a matter of dropping the theme changer app into /system though - at the very least your framework-res and I expect SystemUI will need to support it.
Of course if you know what you are doing you can replace the graphics in those two apks I named above, but the theme changer is a lot more convenient! The UOT kitchen site can be used for theming a lot of ROMs too (though not all of its mods work on all screen resolutions - I just had a look). Just remember that if you are tempted to try a do it yourself change like these, take a nandroid backup before making any changes (my very first bootloop was when I tried a simple theming change and got it slightly wrong ;)).
I thought it was a clone of the note 2. Oh well. Just curious, what makes ROMs device specific? What would happen if I tried using one meant for the galaxy s3 or note 2? Would my phone just brick?
How hard would it be to make a ROM for myself? I'm assuming it's pretty complicated.
Edit: Hardon, I'll look into that. It doesn't sound too out of my league.
Well, Your right, But google is showing me conflicting results on it. Says it is a clone on both. :confused:
You will probably brick the phone using a Rom not designed for it.:(
The 5th result says Galaxy S3 Clone, All the others say NoteII Clone
https://www.google.com/search?q=H71...0&aqs=chrome.0.69i57&sourceid=chrome&ie=UTF-8
What firmware did the phone run when you bought it? Was it samsung firmware or something completely different? Did it have any of the Touchwiz special features?
I have no idea, when it booted it just said android and had this circular thing around it. I think it was completely different.
Alright, I think I will be satisfied with the UOT kitchen, except I am at a loss when it comes to uploading the required files. What ROM zip are they talking about? My ROM came in a .rar file and it is nowhere near the same format that they are asking for. Is there a way to just make a zip of my current ROM, or am I missing something?
If you can extract copies of the apks it needs and upload those it should work.
You have a custom recovery to install zips, right? I'm not at all familiar with this device.
